Front cover/oil pump
ROOKIE1
2,820
3
Aug 25, 2003
Walton, Kentucky
I know everyone says to replace this with gears . My question is , why can I not just change the gears out with new ones ? What could be wrong with the cover itself ?
How does the cover wear out ? It is just a housing . And why are there not any cases already modified for the removed balanced shafts ?
The gears inside rub against the outside of the case. If they start to get worn out and end up getting sloppy then can dig into the case and not only send metal through the motor, also kill the case and oil pump.
The case has nothing to do with the B shaft removal the shoter shaft gets put into a stock case.
If you are think about not using a new case then go ahead but anytime I am that far inot the motor I would put a new one on for piece of mind. I always think of something I heard on this board awhile back.... "How come there is never enough time/money to do it right the first time, but there always seems to be enough time/money to do it again."
I would like this to be a man law . or at least the motto of dsmtuers.com .ROFL :thumb:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
