Front camber kit adjustment. Please help!!!!!
trung_n_nguyen
Jun 1, 2009
Atlantic City, New Jersey
Hi all, thanks for looking to help me through this. I had lowered the front and rear of the vehicle and I know that I'll need camber kit to adjust the camber angle of the wheel. I've done the rear camber adjustment but now I'm stumble on how to adjust the front. I'm looking to buy this camber kit ( INGALLS FRONT CAMBER KIT 95-98 ECLIPSE TALON FWD/AWD - eBay (item 360333018458 end time Feb-01-11 10:51:19 PST) ), but I didn't know how to or where to put them in. If you can please help me. Thank you. :)
yes and its adjustable. But i would have a alignment shop do the final adjustment, because off a little bit good by tires.
Ingalls also makes the upper ball joints for the front. I found them to be of better quality. The SPCs seemed to have a longer bolt that pertruded high enough to smack the inner fender well with large bumps. I switched to the Ingalls that has about 1/4in shorter bolt. makes a difference for suspension travel. You might want to invest in larger bump stops to accomodate for the new adjustable ones. The OEM ones dont have the nut on top, thus your going to need to shorten the suspension travel alittle.
