OnABudget
- 42
- 0
- Jul 21, 2004
Bay Area,
California
hey all, i need someone with experience to explain how i should go about to choose spring height and rate for my 92 awd. like everyone, id like to reduce understeer as much as possible. i plan on a rear sway bar obviously, i have adjustable shcoks as well.
im thinking get stock height springs in the rear with 1" drop in the front. stiffer shock settings in the rear also. im clueless as far as ratios (etc..) go for choosing a spring rate setup.
thanks-
thanks-
I just set my buddy up the some 400's adn 350's for his galant....seems quite good too but the galant could use just a bit more rear spring..... What your damping your springs with will also have a influance on the spring rate choice.... What are you using?
