From internal to external (wastegate)
Easiest way for you is to sell your internally gated bep hotside and buy one that is external. Then buy an external O2 housing like Punishment racing's or MAP's. Bolt on an external wastegate and go.
Its really easy since you have the BEP housing.
The simplest method would involve buying an O2 housing with a waste gate (i prefer the recirculated type), and just replacing your existing o2 housing.
I have the same setup as you and this works perfectly, not to mention is a nice looking piece.
-----> PUNISHMENT RACING | O2 HOUSING / TIAL MVS PACKAGE | RECIRCULATED
Buy some new gaskets at the same time for a tight seal and call er a day.
i have the same o2 housing and it does work good but with the external waste gate you will get more heat under the hood . i had to go to a colder thermostat to keep temps down .
    • dsmmario
    • Canadian_CD9A
    • my98gsx
  • For sale 4G63 Six bolt cy head. Ported. SS O-rings. Ferrara valves.
    Six bolt cy head. Hand ported and flowed by Baker Cylinder heads. He started at Air Flow...
