okm12346
- 565
- 22
- Dec 3, 2007
Chicago,
Illinois
So it was fine during the cooler months, but now every time its above 80 degrees it starts overheating. I add coolant and it pushes it out little by little thru the overflow tank hose. The coolant overflow is full, but it doesnt get sucked in when the system needs it.
Dont have OEM thermostat, but its still the 190 degrees one. The water pump is GMB brand and it has less that 5k miles. Fans dont kick in all the time since it gets low on coolant
I did a little searching and i found that timing being retarded might have something to do with this problem
Any advice is appreciated
