FPR install question
Jason84
948
3
Jul 10, 2003
Manitowoc, Wisconsin
how do you clamp the hose comming out the bottom of the FPR to the stock metal line?
Are you using braided line? I just slipped the braided line over the steel line, leaving the tape that was on the end of the braided line from cutting it there so it wouldnt fray and used a normal worm clamp. Seems to work ok and doesnt leak.
I have the fuel rail inlet line that goes from the stock filter to the rail removing the banjo bolt as thats a very big restriction and the braided lines for the regulator. As of right now I am only running stock hard lines to the stock filter and back from the hard line on the firewall to the tank.
would this be a good enough fuel filter ? for a 255hp
Fuel Filter, Inline Mount, Blue, 85 Micron, -6 AN Male Inlet/Outlet, Each
These Earl's in-line fuel filters provide maximum protection for fuel systems. They're available in your choice of a screen filter or a sintered bronze element. Either unit can be easily disassembled for inspection and cleaning. The filter housings are available with size -6 AN, -8 AN, or hose barb ends (bronze element only) for use with Earl's high-performance fuel line and fittings. They have a fuel flow of 4 to 5 gpm, and come in a nice blue anodized finish.
max fuel pressure is 75
