FPR fittings
Spellmen
146
Dec 3, 2002
York, Pennsylvania
I just bought an Aeromotive AFPR with some fittings because my Walbro 255 is overrunning the stock FPR. The person I bought it from was going to turbo a probe, so I know I don't have all the fittings needed. The AFPR number is 13109, so it has all 6an outlets. I've got 4 Earls -6an fittings, 4 -6an flared fittings, 4 ft rubber line, and 3 ft 6an braided ss line. What do I still need, a 6an weld fitting for the fuel rail and a 6an plug for the other side of the afpr? I don't want to take the fuel rail off and cut it to find out I missed something I need
All you should need:
FPR
Hoseclamps
Fuel injection hose
-6AN rail adapter outlet fitting
-6AN Hose end (x2... one 90*, one straight?)
-6AN SS Hose (long enough to mount the FPR wherever you want it)
-6AN --> Rubber hose bung
You shouldn't have to cut the fuel rail for any purpose.
The outlet fitting bolts right up. Look at the pictures that slowboy has, and you can see what fittings you will need. The above poster I think forgot about the -6 fitting into the FPR, also a block off -6 (because it has two inlets).
Looking at the slowboy kit, it looks like I am missing the two right fittings that are inside the loop of SS line on the return line kit. Can anyone tell me what they are?
On second thought, would I just need the kit that I pictured? Or do I also need the other one they list on their site? If I just need the one pictured I migt as well save myself the hassle of hunting down all these parts because I can easily return the ones I already have and just buy it all in one pop :confused:
They bolt onto the FPR so you can connect hose to them. the one on the top right is a plug.
