Turbocharged
- 539
- 14
- Dec 12, 2002
Minneapolis,
Minnesota
It says on the website to use dual springs. What more do you guys need. I have to believe that FP is fed up with email titled "fp3's requires dual valve springs"?
Run whatever springs you want but do so at your own risk.
And yes this is what they recommended even with an aftermarket single spring.
, whoops fellas, yeah yall are definitely right that a stroker has faster piston speeds at same RPM points as a non-stroker, I don't know what the hell I was thinking. Too many beers in me I suppose.
. I was thinking you had posted all this & then were saying the 415 needed more springs then the 3's, but after I reread your posts I see you are saying the opposite, which I second
