fp2 cam and manley spring ???? help
HIGHREV
Apr 18, 2005
WORCESTER, Massachusetts
I just in stall a new set of fp2 cam and manley valve spring .
try to turn it over but it really hard , this is normal? I torque all the cam cap to 14lb .
all the cap in right position from 1-5 intake and exhaust so what wrong .ROFL
it a 1g motor brand new head just rebuild .
please help me thank
Are you turing the engine and head over by hand or w/ starter.?
Are you jsut turning cams over by hand? is the head on the block when doing this?
When just rolling over the cams w/ the head off the block, it will be harder than stock because there is more lift form the cam lobes AND you have stronger spring pressures from the spring upgrade.
