Manley valve spring pressure question
InvaderGSX
135
Jul 16, 2004
Kentwood, Michigan
OK doing research on running the proper springs. These are the ratings I received. Wondering if anyone on here can calculate it for me as I have no idea. Most valve spring companies rate the springs at 1.110 inch. The Manley's are rated at 1.05"
FP duals valve spring=250 [email protected]"
Ferrea duals= 210 [email protected]"
Crowers=190 psi @1.110"
Manley=222 [email protected]"
So basically I am trying to figure out the Manley psi rating at 1.110" rather than the 1.05" rating they provide so I can properly compare it to the others at 1.110". Please post if you know how to figure it out. Thanks
Yes very happy! thanks! I specified in the original post that I have no clue how to calculate it. That's why I posted that. Thanks that helps me out a lot! That's not bad at all. Only 6 psi less than the Ferrea dual valve spring.
