FP Red / Black Internal W/G
Luke Evo
Oct 7, 2014
England UK, Europe
Anyone running Fp Red or Black with internal wastegate?
If so how much boost do you run it on do have any issues with it spiking / creeping?[DOUBLEPOST=1413412904][/DOUBLEPOST]Also regarding external wastegate for FP Range turbo would this do the job i am a bit clueless with it all myself an will just buy what i need an take it to tuning company to fit an map adjustments. On a forged evo 123 4g63 kelford 272's etc etc..[DOUBLEPOST=1413412963][/DOUBLEPOST]http://www.punishment-racing.com/pu...-vented-o2-housing-package-for-eclipse-talon/
I have this exact O2 housing with a Tial 38mm wastegate and an FP Black JB. I love the setup and couldn't be happier. The only thing I might consider is potentially a slightly larger diameter wastegate but in totaly, that setup is very responsive and dead accurate every pull.
Thanks Dog Whistle
What is the FP Black Like what power you make on pump gas only? I debating which JB Red or Black to buy
How much boost do you run???
It should be in my profile, but 28psi and I am tuned on e70 and run between that and e85 from the pump as the seasons change here. I am not pushing any timing more than adding/subtracting 1 degree here and there so I imagine high quality pump gas would yield similar numbers. It spools around 3.5K-4.5K depending on how soon you step on it and it hit hard and quick. I make peak power at 6.5K due to FP2 cams and being a 2.3 where I don't rev much anyway. I would suggest the black if you're okay with the slightly longer spool. The lag isn't bad and I recently drove an FP green car in comparison to mine and still wound up loving the final amount of kick the black has.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
