fp big t28 or evoIII big 16g
TSImuchforyou
56
Aug 7, 2005
Twin falls, Idaho
i have a 1995 GSX auto :cry: i have a problem with turbo lag due to auto but i have many mods such as 2.5 inch dp and 3 inch exhaust 1g head 1g tb and intake dejon tools big sidemount soon to be fmic 650cc injectors safc2 and innovative wide band i was wondering if i should go with a fp big t-28 or a evo III big 16g? also forgot to ass a i have a 255lph walbro and a fpr 1-1
They are basically in the same league.
Though I prefer the EVOIII
since you are 2g, there is a few things youll have to do to install the evoIII, But the t28 is direct.
Here is a write up on installing 16g style turbos in 2nd gen cars.
http://www.vfaq.com/mods/2G-16G.html
Here is a Link to purchase a Pre assembled 2g install kit for this turbocharger.
http://www.dsmparts.com/customer/product.php?productid=600&cat=166&page=1
Basically, I would say the evoIII is a better turbo charger.
it gets good reviews, everyone seems to like it. I think the t28 is a 2g 16g basically. Though I dont have flow numbers to verify this.
The T28 is a direct bolt-on; while the 16g will require a 2g install kit, but not that hard to install.
T28 will spool SLIGHTY faster and were talking about a hundread or two rpms faster, but the 16g will have a stronger powerband. The 16g has been proven to outperform the t28, I will go with the 16g :thumb:
Stay boostin
Hi. There is a lot of info on this already. Just use the search button. Anyway, I would go with the evoiii 16g since it has a little more potential and is much cheaper. As far as installation goes, all you need is a ss braided oil feed line (about $40) and a 1g j-pipe ($10-20). You can reem out the holes on the oil return to make it fit properly. The water line will work without modification.
