Found this in my oil pan....
ILLiCliPSE
1,576
4
Jan 11, 2003
Boynton Beach, Florida
FINALLY started to tear apart my 6-bolt that's been laying around for a while in my garage. I bought the motor from my old mechanic who got it out of his friends wrecked 2g that had a 6-bolt. Long story short, I pulled the oil pan off, and found this laying at the bottom. Kinda new to engine building, so bear with my lack of knowledge...
Doesnt look like a rod bearing, its (or was) a full circle, not 2 half moons. Hmm, any ideas? If I spin the rotating assembly it doesnt really make any abnormal noises, and spins free. Maybe it gets a bit harder in places, then it'll spin easily, but maybe thats because its been sitting for so long? Hope the crank is ok, if not, 2.3 stroker:p
Thanks for the help,
Brian
hey man, MAKE SURE you clean that block and head out as much as you can, stick a power washer point bland into all the holes on the block before you take it to get tanked and cleaned/painted (its what i do with all my builds) :D also your crank is more then likly messed up:sosad: i really hope not man :( :, before you decide to throw alot of money back into the build if you do, i WOULD NOT get the crank cut. Dont take the chance with all that money you tie up into it. get a new one Mitsubishi says "they are not servicable" because of the treated nitride coatings on the journals of the crank, this leaves your crank softer and less durable (some people have success from cutting though so im not kocking it). But hey, your build.. your decision i would also take those few allen key plugs out of the oil galleries on the head and clean all them out good as well, better be more safe then sorry :thumb:
if you need any help or suggestions at all PM me man ill be glad to help you since your new to engine building:hellyeah::hellyeah:
