jtmcinder
DSM Wiseman
- 5,402
- 96
- Nov 4, 2003
Iowa City,
Iowa
The key issue to rear-tire fitment on a 2G is the corner of the tire, which comes very close to the rear knuckle. When you go to a bigger-than-stock diameter, you must move the tire outwards to avoid contact here. So, while a 245/40/17 Kumho MX does not rub on a +40mm offset, a 245/45/17 of the same design would definitely hit the knuckle on the same wheel.
Given that the knuckle is at about a 45-degree angle at the point of contact, my first guess would be that you would need to drop the offset by about 10mm to get 245/45/17s to fit, but this will depend a lot on the brand of tire. Azenis, for example, have very wide treads for their stated width, while Kumho MXs are average. If you can learn the actual tread width of the tire that you are considering, then you might be able to figure this out.
The next issue, however, might change your mind. When you decrease the offset, the outside edge of the tire comes closer and closer to the fender lip (rolled or not). I'm doubt that a 245/45/17 on a +30mm offset will tuck in. Maybe it will if you don't have a rear camber kit, but I doubt it. And who runs a 2G will no rear camber kit?
- Jtoby
- Jtoby
I really do not want this thread to turn into somethign stupid and have a bunch of people arguing with me, so hear me out before you shit your guys' pants and start trembling on the keyboard ready to type what biggot I am....
Dont be one of those guys that turns threads into something they aren't, nowhere in my post does it show I even hinted that. So just stop before its gets silly k...
) where the side wall is small enough on both widths (tires compared) then this is sort of the breaking point to where maybe you shoudl stop and say "I do not really need anythign wider than this as it wont do much for me--espeically since I am AWD--aside from make me spend more money on tires).
Well that doesent matter.
