Cobra Brakes
97spyder maayng
71
Sep 11, 2004
toronto,
So i've made my 1g into a stroker and now i need much better brakes without breaking the bank.
Ive heard cobra brakes work and are quality, but what do i need? (obviously rotors and calipers...)
What year cobra rotors and calipers will fit?
THANX
This will work if you get the corresponding 13" rotors. It seems the years are 94-04.
http://store.summitracing.com/partd...20-F&N=700+4294922533+400070+115&autoview=sku
http://store.summitracing.com/partd...21-A&N=700+4294922533+400070+115&autoview=sku
http://k-mansparts.com/browse_item_details.asp/Item_ID/148
I believe they're set up for banjo fittings. Apparently the 2g banjo fitting fits, but you need to use the ford banjo bolt. I might have misunderstood the guy I was talking to though, and I haven't tried it yet, so you'll have to double check. You obviously need custom brackets. The largest master cylinder you can find might help too (which is a 1" for dsm's). You can also get 15 dollar rotors from Autozone.
