Fog Lighting issue, mirror lights too
MarcVIII
103
Oct 23, 2004
Cleveland / Akron, Oh, Ohio
Tried searching but to no avail...
Ok so my fog lights work cause my passenger one shines. I even wired it to function with the high beams. No problems. But the driver's side foglight doesn't work even after installing a good bulb (didn't work before the light mod). The grounding on the bulb is clean. Is there a bad section of wire, relays / fuses or way to check it? Odd that only one works.
Also when I open my doors the mirror light doesn't function. I know they work because they light when i flip the switches and when I use my keyless entry. I'm guessing its a bad door switch, but wouldn't the lights work if the passenger door was opened (which will still doesn't work). Let me know guys.
Both of your door switches probably went out. If that's the case, buy the part from Mitsu, and do the install yourself. They just pop in, if memory serves me correctly, and there's no need to be charged for a minimum of 15 minutes or so (what's that, $20 now?) for them to do it. I once got charged 15 minutes of labor for a guy to pop on the little metal spring clip that pops the gas door open. It's a 50 cent part.
Both of them to go out? Hmmm that sound s a little strange. That part looks like the same on the Serbring JXi I was messing with. I guess I have 3 of those suckers to buy then.
BTW just got my Translab Shift Kit in and WOW the best thnig that the car needed. It feels like a new tranny, no sluggishness anymore.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
