Flywheel Exposed?
kidmet
Supporting Member
217
21
Jul 23, 2012
Aurora, Colorado
What is missing here? Is the flyweel always exposed?
1997 GSX, Stock turbo, Automatic transmission.
Looks like you are leaking something to. Red fluid to be exact. Atf maybe?
Edit
Just noticed the antifreeze on the cross member too.
She's leaking lots of stuff. I know where its all coming from. I sold her but am helping new owner a bit. The big prob is a grinding noise at start now. Just started. Sounds worse when roms rise. Could be turbo as it didn't spool when this started. Didn't feel any shaft play though.
had a starter problem and put the new one in. Maybe it's the wrong starter. I know manual and automatics have different starters. As well as turbo/non turbo.
Auto and manual do have different starters. Make sure the correct starter plate is used in between the engine and trans and if the starter is matching.
Just to correct the thread title, Autos do not use a Flywheel, only manuals have that. What you see in the first pic is the Torque converter with the inspection plate removed.
