Flat Valve Cover
DSMsamurai666
89
Feb 9, 2009
Macomb, Michigan
I want to make the top of my valve cover perfectly flat. Think it would be ok if I cut off the lettering and then maybe smoothed it out with bondo and some sandpaper? I just don't want to ruin anything. Know if this will work?
Have a shop shave the VC for you. They just grind the lettering off and it looks really good. Probably something you don't want to do yourself just in case you go too far when grinding and ruin a perfectly good VC.
I suggest you powdercoat your VC after you get it shaved. Mine used to look identical to^ that polished one. It is a complete pain in the dick to keep polished and totally not worth the hassle.
Isn't there a flat cover that came stock on Hyundais with the 4g63? Maybe you could find one of those cheap and save yourself some work.
i'm using a dremel and a router tool that you can buy and it cuts like butter, then using the 80 grit sand paper that you can also buy for dremels to smooth it out more then off to Powdercoat..i guess i can take some pics of the process and tools
