danny_l_2005
- 511
- 1
- Mar 23, 2004
weslaco,
Texas
I took my block to check the bore and pistons. The guy said that the cylinder do not need to be bored out and that it's needs to be honed.
My question is how hard is it to hone the cylinder wall. I can rent a cylinder hone from Oreilly's for around 30 dollars. I am also in need of new rings, what rings should I get the chrome type or moly rings? Is there a special way as to putting the rings onto the piston as I read around here about ring gap clearance...I thought you only used a ring gapper to put the rings on the piston.
