General First time logger
JTURBOGSX
178
Jun 22, 2004
niagara falls, New York
So being A newb to the whole logging thing I have everything hooked up went through all the settings etc. Now im ready to do my first log What should I log on my first run. Also How long should the log be 3rd gear pull.? Also trying to figure out how to view them so I can post them up I have pocket log viewer.
My mods evo 3 16g
walbro 250
punshiment racing fmic
2.5 turbo back
mbc set at 16psi
thanx
here is my first log does everything look ok ?
Only thing weird I see is your IDC's are high, whats your W/B reading its hard to see what it is.
I have larger injectors but I need some thing to tune with LOL I have 650s I was going to wait to install them
You'll want to take care of your FT's first before you start making pulls. Search, using my username and you can find the correct way to set your trims. Are you running larger injectors? What are you using to tune?
To view the logs, you'll need to download PLViewer from the PocketLogger website.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
