First time at track with new mods. Have questions.
2GturboTALON
607
6
Nov 26, 2002
St. Peters, Missouri
I'm going to the track Friday to see what my car can do but i'm a little worried about my egt's. I have only my loggger w/obd guage to check my engine and wanted to know if there were any things i should look at while diong my runs to make sure things look ok. My logger shows that i am at 0 on my trims throughout the rpm range. Should i be worried? Should i use 93 or should I try some 100+ gas.
Mods:
Fp Big T28 ported w/ 17 psi actuator
Forge 1g Bov
Dejon full intercooler piping
stock 2g sidemount
conefilter
greddy profec ebc
full apexi 3in exhaust
poted O2 housing
evo 560cc injectors
evo 8 "almost 190" fuel pump
SafcII
Ngk bpr7es plugs
Just watch your timing curve, it should dip to around 9 when boost hits and steadily climb to around 18 degree's. If there's a flat spot or the timing goes down the car is knocking...
Make sure to give that little intercooler time to cool down in between runs, bring a spray bottle and spray it down with water before each run.
