First Log, Now I Have Questions
alex99gst
1,335
24
Feb 10, 2003
Nashville, Tennessee
I just recently got a datalogger and wanted to check and see how everything was running and if I was getting any knock I didn't know about. As it turns out, I ran into some problems when doing my first pull. This log is of a 1st - 3rd gear pull in which consitently, through every gear, I would get to a certain rpm (about 4500-6000) and I would suddenly feel a big slam like I just busted through a house. My power would end quickly and I wouldn't be able to get any higher than that particular rpm range in that gear. This happened multiple times where I couldn't go past 4500 rpm's in 3rd gear. I am assuming that my O2 sensor is by its consistent readings of 0.06v I remember reading that the timing being measured can only reach 43* on the logger, but I seemed to have hit that mark. My mods are listed and I am only running 14 lbs of boost. Any information or suggestions as to what the problem could be is appreciated. I attatched the log text file to the bottom if this is illegible.
LOG:
RPM Knock Timing O2 TPS
844 0 11 0.06 10
844 0 9 0.06 10
844 0 12 0.06 10
844 0 10 0.06 10
844 0 11 0.06 10
844 0 10 0.06 10
844 0 10 0.06 10
875 0 9 0.06 10
875 0 9 0.06 15
906 0 13 0.06 17
1125 0 22 0.06 18
1531 0 28 0.06 18
1688 0 30 0.06 18
1688 0 29 0.06 21
1438 0 26 0.06 24
1375 0 23 0.06 24
1500 2 23 0.06 24
1438 1 21 0.06 25
1406 1 21 0.06 27
1719 1 21 0.06 28
2031 0 23 0.06 28
2281 0 25 0.06 32
2563 0 26 0.06 33
2875 0 26 0.06 42
3250 0 24 0.06 44
3656 0 22 0.06 82
4125 0 18 0.06 91
4688 0 19 0.06 69
5469 0 22 0.06 51
6063 0 29 0.06 10
5219 0 45 0.06 10
4594 0 44 0.06 61
3344 0 20 0.06 100
3313 0 18 0.06 100
3719 0 17 0.06 100
3875 0 17 0.06 100
4125 1 17 0.06 100
4344 1 17 0.06 100
4531 1 17 0.06 100
4688 0 19 0.06 100
4531 0 18 0.06 100
5188 0 19 0.06 10
4375 0 43 0.06 10
3844 0 41 0.06 10
3344 0 40 0.06 50
3406 0 26 0.06 100
3438 0 22 0.06 100
3469 0 16 0.06 100
3531 0 15 0.06 100
3625 0 16 0.06 100
3750 0 17 0.06 100
3844 0 17 0.06 100
4000 0 18 0.06 100
4094 1 16 0.06 100
4281 0 18 0.06 29
4000 0 35 0.06 10
3938 0 41 0.06 10
3406 0 40 0.06 10
3000 0 26 0.06 10
2719 0 25 0.06 10
2344 0 25 0.06 10
2031 0 23 0.06 10
1688 0 15 0.06 10
1406 0 17 0.06 10
1188 0 22 0.06 10
1188 0 26 0.06 10
1125 0 24 0.06 10
1125 0 21 0.06 10
1094 0 19 0.06 10
1063 0 18 0.06 10
1063 0 18 0.06 10
1063 0 15 0.06 16
No knock is good, but without any fuel mods, a s16g at 14psi might trigger enough airflow to hit fuel cut..Also, that 02 sensor is definitely having issues
For the next log, try to just do a 3rd gear pull ONLY
I had a log of an only third gear pull, but it looked the same as that one just with constant build ups and then sudden drop offs :notgood: Ill get a new O2 sensor and see what happens. Thanks guys
