First log
spoolintsi97
56
Apr 16, 2005
Blandon, Pennsylvania
This is my first log I am runing a maft and afc the afc is zeroed out and the maft i am working on here is my first log i think this is how you write it out and my afc showed little or no knock
RPM O2 Timming
2072 .84 24
2636 .02 23
3000 .16 27
3400 .64 12
3840 .98 12
4244 1.00 13
4608 1.00 14
4940 .98 15
5272 .98 17
5564 .96 20
So where do i go from here
Are you only logging those three sensors because you are not getting much data at all. Try logging no more than 3 different things. Also check your options to see if you can get info every 200 rpm's. Your jumping data every 500rpms. Also make sure you do a run to 7000 or to where ever you rev too. But with the data you gave it looks good. Also how much boost was this. You can start adding boost and fuel untill you cant control knock. Also the AFC knock feature does not work with our cars so dont go by that. The only way to see the knock is to look for dips in the timing curve but yours looks ok with the little data you provided
i will try to get a better log i just wanted to see if it was going right so i dont mess up my engine last time i tried to tune i hit fuel cut bad so now im taking it easy also it keeps throwing a cel i think it was a 0105 manifold absolute pressure/ baromic pressure also what would be considerd high egts
