First log
slowdsm1
May 19, 2004
iowa city, Iowa
this is 15 psi
Time,RPM,Timing,O2 1 Bank 1,O2 Trim 1 Bank 1
00:00.39, 2856.0, 33.0, 0.82, -1.56
00:00.76, 2900.0, 28.0, 0.92, 0.0
00:01.13, 2920.0, 28.0, 0.9, 0.0
00:01.52, 2988.0, 28.0, 0.92, 0.0
00:01.89, 3028.0, 24.0, 0.94, 0.0
00:02.26, 3096.0, 24.0, 0.94, 0.0
00:02.63, 3116.0, 23.0, 0.94, 0.0
00:03.01, 3184.0 ,22.0, 0.94, 0.0
00:03.41, 3240.0, 22.0, 0.94 ,0.0
00:03.78, 3296.0, 22.0, 0.92, 0.0
00:04.13, 3344.0, 22.0 ,0.92, 0.0
00:04.52, 3428.0, 22.0, 0.92, 0.0
00:04.90, 3460.0, 22.0, 0.92, 0.0
00:05.28, 3504.0, 21.0, 0.92, 0.0
00:05.65, 3592.0, 21.0, 0.92, 0.0
00:06.03, 3652.0, 21.0, 0.9, 0.0
00:06.42, 3668.0, 20.0, 0.9, 0.0
00:06.77, 3728.0, 20.0, 0.92, 0.0
00:07.15, 3812.0, 20.0, 0.92, 0.0
00:07.53, 3876.0, 20.0, 0.92, 0.0
00:07.90, 3892.0, 21.0, 0.92, 0.0
00:08.28, 3956.0, 21.0, 0.92, 0.0
00:08.65, 4028.0, 21.0, 0.92, 0.0
00:09.03, 4072.0, 20.0, 0.92, 0.0
00:09.42, 4164.0, 20.0, 0.92, 0.0
00:09.80, 4260.0, 20.0, 0.94, 0.0
00:10.17, 4268.0, 21.0, 0.94 ,0.0
00:10.55, 4340.0, 21.0, 0.94, 0.0
00:10.90, 4416.0, 21.0, 0.94, 0.0
00:11.28, 4468.0, 21.0, 0.94, 0.0
00:11.67, 4536.0, 21.0, 0.96, 0.0
00:12.03, 4604.0, 21.0, 0.96, 0.0
00:12.42, 4652.0, 21.0, 0.96, 0.0
00:12.79, 4716.0, 20.0, 0.94, 0.0
00:13.15, 4716.0, 20.0, 0.94, 0.0
00:13.53, 4776.0, 20.0, 0.94, 0.0
00:13.90, 4824.0, 20.0, 0.94, 0.0
00:14.28, 4888.0, 20.0, 0.94, 0.0
00:14.68, 4980.0, 20.0, 0.94, 0.0
00:15.05, 5012.0, 20.0, 0.94, 0.0
00:15.43, 5036.0, 20.0, 0.96, 0.0
00:15.80, 5144.0, 19.0, 0.94, 0.0
00:16.17, 5216.0, 19.0, 0.96, 0.0
00:16.55, 5280.0, 19.0, 0.96, 0.0
00:16.92, 5272.0, 19.0, 0.96, 0.0
00:17.29, 5316.0, 19.0, 0.96, 0.0
00:17.67, 5384.0, 18.0, 0.96, 0.0
00:18.04, 5420.0, 20.0, 0.96, 0.0
00:18.43, 5492.0, 20.0, 0.96, 0.0
00:18.79, 5540.0, 19.0, 0.96, 0.0
00:19.17, 5564.0 ,20.0, 0.98, 0.0
00:19.54, 5688.0, 20.0, 0.98, 0.0
00:19.93, 5704.0, 20.0, 0.98, 0.0
00:20.29, 5780.0, 19.0, 0.98, 0.0
00:20.68, 5780.0, 20.0, 0.98, 0.0
00:21.04, 5844.0, 20.0, 0.98, 0.0
00:21.43, 5852.0 20.0, 0.98, 0.0
00:21.79, 5924.0, 19.0, 0.98, 0.0
00:22.17, 6008.0, 19.0, 0.98, 0.0
00:22.54, 6008.0, 19.0, 0.98, 0.0
00:22.90, 6132.0, 19.0, 0.98, 0.0
my mods are, 6bolt, no b/s,web cams 264/264,hks cam gears, egr block off,255 fuel pump w/rewire,650 injectors, SX fpr,injen intake,sbr 20g ported w/ 38mm flapper,o2 dump, apex-i N1 cat back and downpipe no cat, stock side mount but hard pipes
for tuneing i only have afc 1 and logger that i just got
yeah i was WOT 4th gear
your not getting any knock since your timing isnt bouncing around and your o2 is high.lean her out a bit and log again.youll notice you timing going down when you start knocking.on my tsi,my o2 is around .85 at wot,but i tune for zero knock.
Thanks i will do another log and see how that looks
what should my timing be and o2's
check this one i leaned it out a little more
00:00.38,2800.0,34.0,0.02,-4.69
00:00.75,2960.0,34.0,0.02,-4.69
00:01.12,2828.0,29.0,0.56,0.0
00:01.51,2856.0,28.0,0.08,0.0
00:01.88,2892.0,28.0,0.06,0.0
00:02.26,2936.0,27.0,0.1,0.0
00:02.63,2976.0,26.0,0.8,0.0
00:03.00,3016.0,24.0,0.88,0.0
00:03.40,3076.0,24.0,0.88,0.0
00:03.76,3124.0,23.0,0.88,0.0
00:04.15,3152.0,23.0,0.88,0.0
00:04.52,3244.0,23.0,0.88,0.0
00:04.88,3284.0,22.0,0.86,0.0
00:05.28,3368.0,22.0,0.86,0.0
00:05.65,3404.0,22.0,0.86,0.0
00:06.03,3456.0,22.0,0.86,0.0
00:06.40,3528.0,22.0,0.86,0.0
00:06.77,3592.0,22.0,0.86,0.0
00:07.15,3664.0,22.0,0.86,0.0
00:07.52,3692.0,22.0,0.86,0.0
00:07.88,3780.0,22.0,0.86,0.0
00:08.27,3820.0,22.0,0.86,0.0
00:08.64,3884.0,22.0,0.86,0.0
00:09.02,3952.0,22.0,0.84,0.0
00:09.39,3984.0,22.0,0.84,0.0
00:09.77,4024.0,21.0,0.86,0.0
00:10.14,4092.0,21.0,0.86,0.0
00:10.52,4172.0,21.0,0.88,0.0
00:10.89,4216.0,21.0,0.88,0.0
00:11.27,4236.0,21.0,0.88,0.0
00:11.64,4352.0,21.0,0.88,0.0
00:12.02,4408.0,20.0,0.9,0.0
00:12.39,4412.0,21.0,0.9,0.0
00:12.77,4464.0,21.0,0.9,0.0
00:13.14,4528.0,21.0,0.9,0.0
00:13.52,4544.0,21.0,0.9,0.0
00:13.89,4624.0,20.0,0.92,0.0
00:14.27,4664.0,20.0,0.9,0.0
00:14.64,4732.0,20.0,0.9,0.0
00:15.02,4800.0,20.0,0.9,0.0
00:15.39,4840.0,20.0,0.9,0.0
00:15.77,4948.0,19.0,0.9,0.0
00:16.14,4964.0,20.0,0.92,0.0
00:16.53,4984.0,20.0,0.92,0.0
00:16.89,5032.0,19.0,0.92,0.0
00:17.27,5140.0,19.0,0.92,0.0
00:17.64,5132.0,19.0,0.94,0.0
00:18.02,5236.0,19.0,0.94,0.0
00:18.39,5280.0,19.0,0.94,0.0
00:18.77,5360.0,19.0,0.94,0.0
00:19.14,5416.0,19.0,0.94,0.0
00:19.53,5444.0,20.0,0.94,0.0
00:19.88,5492.0,19.0,0.94,0.0
00:20.28,5484.0,19.0,0.94,0.0
00:20.64,5524.0,19.0,0.94,0.0
00:21.04,5588.0,19.0,0.94,0.0
00:21.42,5628.0,20.0,0.94,0.0
00:21.79,5660.0,20.0,0.94,0.0
00:22.15,5720.0,19.0,0.96,0.0
00:22.54,5780.0,19.0,0.96,0.0
00:22.90,5800.0,19.0,0.96,0.0
00:23.28,5880.0,20.0,0.96,0.0
Something is way off, your timing should drop to around 9 when boost hits and then steadily climb back up to around 19ish.
Also .94 is a good o2 to shoot for with a 2g.
i was thinking something was wrong ### when i had my 7 bolt it pulled way harder then now
what do you think the problem could be or something i should look at
