First log
top_end95
589
Jan 23, 2003
Dallas, Texas
Im having a little trouble with posting the log, but I felt the one down below is good enough :p
For some reason the data is getting cut off when being copied. I made a pull to 6500 RPM with the Inj D/C topping out at 92% and timing at 22.
Mods:
K&N
2.5" Downpipe mated directly to a muffler.
Stock boost
Stock fuel
The timing has me concerned as I believed it should only be 18-19 degrees? I am wanting to at least run 14-15psi for the time being until I go with a bigger pump. May also have some boost leaks that I need to fix before doing anything, but wont know for sure until Wednesday.
What do you all think? Good or bad log? Any recommendations?
Code:
Time,          RPM,    Knock,     Timing,        Inj D/C
00:00.11,    3250.0,   1.0,        21.0,         31.93
00:00.22,    3313.0,   1.0,        21.0,         32.55
00:00.32,    3344.0,   0.0,        23.0,         33.58
00:00.43,    3375.0,   0.0,        23.0,         34.62
00:00.54,    3406.0,   0.0,        22.0,         34.94
00:00.64,    3438.0,   0.0,        23.0,         35.27
00:00.75,    3500.0,   0.0,        23.0,         35.9
00:00.86,    3531.0,   0.0,        22.0,         36.96
00:00.96,    3563.0,   0.0,        23.0,         36.55
00:01.07,    3625.0,   0.0,        23.0,         37.19
00:01.16,    3625.0,   0.0,        23.0,         37.19
00:01.27,    3688.0,   0.0,        23.0,         38.6
00:01.37,    3688.0,   0.0,        23.0,         38.6
00:01.48,    3750.0,   0.0,        22.0,         40.06
00:01.58,    3781.0,   0.0,        22.0,         39.57
00:01.70,    3844.0,   0.0,        22.0,         41.07
00:01.79,    3844.0,   0.0,        23.0,         41.07
00:01.91,    3906.0,   1.0,        21.0,         42.58
00:02.00,    3906.0,   1.0,        21.0,         43.39
00:02.10,    3969.0,   0.0,        22.0,         44.09
00:02.22,    4000.0,   0.0,        22.0,         44.43
00:02.32,    4031.0,   0.0,        22.0,         45.65
00:02.44,    4094.0,   0.0,        21.0,         46.36
00:02.53,    4094.0,   0.0,        21.0,         47.25
00:02.65,    4156.0,   0.0,        21.0,         47.97
00:02.74,    4156.0,   0.0,        22.0,         48.83
00:02.84,    4219.0,   0.0,        21.0,         49.57
00:02.97,    4281.0,   0.0,        22.0,         51.23
00:03.08,    4313.0,   0.0,        22.0,         51.61
00:03.21,    4406.0,   0.0,        22.0,         52.73
00:03.29,    4406.0,   0.0,        22.0,         53.64
00:03.38,    4406.0,   0.0,        21.0,         53.64
00:03.50,    4469.0,   0.0,        22.0,         54.41
00:03.61,    4563.0,   0.0,        21.0,         56.54
00:03.71,    4625.0,   0.0,        21.0,         57.31
00:03.79,    4531.0,   0.0,        21.0,         57.13
00:03.90,    4656.0,   0.0,        21.0,         58.7
00:04.00,    4688.0,   0.0,        21.0,         59.11
00:04.09,    4750.0,   0.0,        20.0,         60.88
00:04.21,    4719.0,   0.0,        21.0,         61.5
00:04.32,    4875.0,   0.0,        20.0,         62.48
00:04.42,    4844.0,   0.0,        21.0,         62.08
00:04.52,    4875.0,   0.0,        21.0,         63.54
00:04.63,    4781.0,   0.0,        20.0,         62.31
00:04.73,    4906.0,   0.0,        21.0,         63.94
00:04.82,    4781.0,   0.0,        21.0,         62.31
00:04.94,    5031.0,   0.0,        21.0,         65.57
00:05.05,    5063.0,   0.0,        21.0,         65.99
00:05.15,    5000.0,   0.0,        21.0,         65.17
00:05.26,    5125.0,   0.0,        22.0,         66.8
00:05.36,    5219.0,   0.0,        22.0,         68.02
00:05.46,    5188.0,   0.0,        21.0,         67.62
00:05.57,    5063.0,   0.0,        22.0,         65.99
00:05.67,    5188.0,   0.0,        21.0,         67.62
00:05.77,    5125.0,   0.0,        22.0,         66.8
00:05.88,    5344.0,   0.0,        22.0,         69.65
00:06.00,    5406.0,   0.0,        22.0,         71.63
00:06.11,    5281.0,   0.0,        23.0,         69.97
00:06.21,    5469.0,   0.0,        22.0,         71.28
00:06.32,    5344.0,   0.0,        23.0,         70.81
00:06.44,    5500.0,   0.0,        22.0,         74.02
00:06.55,    5375.0,   0.0,        23.0,         72.34
00:06.67,    5406.0,   0.0,        24.0,         72.76
00:06.77,    5625.0,   0.0,        24.0,         74.53
00:06.88,    5531.0,   0.0,        23.0,         73.29
00:06.98,    5688.0,   0.0,        24.0,         76.55
00:07.11,    5531.0,   0.0,        25.0,         74.44
00:07.21,    5656.0,   0.0,        24.0,         76.12
00:07.32,    5625.0,   0.0,        24.0,         75.7
00:07.40,    5656.0,   0.0,        24.0,         77.35
00:07.51,    5875.0,   0.0,        24.0,         79.07
00:07.63,    5656.0,   0.0,        26.0,         74.94
00:07.72,    5781.0,   0.0,        26.0,         77.8
00:07.84,    5750.0,   0.0,        26.0,         78.63
00:07.94,    5938.0,   0.0,        26.0,         81.2
00:08.05,    5875.0,   0.0,        25.0,         79.07
00:08.15,    5906.0,   0.0,        27.0,         79.48
00:08.27,    5938.0,   1.0,        27.0,         79.92
00:08.35,    6094.0,   1.0,        27.0,         82.02
00:08.44,    5969.0,   1.0,        27.0,         80.33
00:08.56,    5938.0,   1.0,        27.0,         81.2
00:08.68,    6063.0,   1.0,        26.0,         81.6
00:08.77,    6219.0,   0.0,        27.0,         83.7
00:08.89,    6188.0,   0.0,        25.0,         83.28
00:08.98,    6188.0,   0.0,        24.0,         84.62
00:09.06,    6188.0,   0.0,        24.0,         85.96
00:09.18,    6344.0,   0.0,        25.0,         88.13
00:09.30,    6313.0,   0.0,        23.0,         87.7
00:09.40,    6219.0,   0.0,        24.0,         86.39
00:09.52,    6406.0,   0.0,        24.0,         88.99
