First log with new 6 bolt
fallenauthority
692
11
Oct 14, 2004
La Plata, Maryland
Ok I finally got my 6 bolt in and its running good, or seems to be. Still new to tuning so i need some help getting me started, here is a log of a long drive i took which shows my fuel trims how do i need to adjust this to be as close to 0 as possible? Also if you notice anything out of the ordinary or something that might be a problem could you point it out? Thanks guys. BTW, this is with the stock 450 injectors and all, big16g turbo at 7lbs. http://home.comcast.net/~fallenauth...n08132006-2.dat
Right click, save as
It does work to Right-click and do Save as. But to make things easier you should add it as an attachment to your post. When you "Go Advanced" with your post hit the paper clip and it will allow you to upload a .dat file and attach it to your post.
