First Log with DSMLink
1glaserturbo
591
3
Feb 12, 2005
Creve Coeur, Missouri
:thumb:
Very happy with the results. I need to update all of my information so you can see what kind of mods I'm running.
This was on a built 2.0, FP3065, 25 psi, 93 octane, and a bunch of other stuff.....
Boost leak test it.. 52lbs a minute airflow aint to bad either.
I just looked at your fuel and man you are pulling a lot of fuel out. What injectors are you running?
Are you using methanol injection? Something isn't right. 25 psi on 93 octane with that much timing, pulling that much fuel..
^^ I agree. It seems very odd that you have 0 knock running that lean unless you have meth or were running race gas. You also need to put in your car specific information into your logs. You do this by hitting F4, click on A/F Ratio, and click on the properties button. Repeat for BoostEst and HP.
No methanol injection, 93 octane. Hell, I was just as confused as you guys were, so confused that I ran the tank dry and refilled it with 93 from the local 7-11 up the street. Made another run and logged the same exact thing.
I am telling you man, go to the source. Tom and Dave don't like it when we post outside of the Link Forums, especially when its his product we are using and you have problems. There obviously is something wrong, if you have completley dried out the tank, then tried it again, and it done the exact same thing. Everyone here can view it, but only true members can view link forums.
Something ain't right for sure, LOL. 52lbs/min and 264 hp?? Thats more airflow then dsmlink is reporting for me and I'm just a bit over 460hp and bottom 11's........
Your a/f ratio properties aren't even set up. Where's the wideband???
He's running a MAFT, which you can see by it locking the intake temp. This screws up the airflow numbers. Check out the dsmlink wiki and do the MAFT calibration to set up your airflow sliders.
If I recall when I looked at it yesterday, the airflow sliders weren't even moved from 0 at any Hz level. Definitely needs calibrated at the least.
Your maft definitely needs calibrated. Do you have a wideband or a map sensor? Did you set fuel pressure to 37 psi with the vacuum line off?
