first dsmlink log with hx35 not boosting
deviousgst
931
Mar 24, 2008
bakersfield, California
hey wats up guys, AND girls, i finally finished my gsx build:hellyeah:
but i have some problems, i think i have everything dialed in pretty good, car idles fine except at times, when i hit the 2 step( wanted to see if it worked) it will die out after like the 3rd time doing so, i would have to hold the idle up myself by pressing pedal till it starts idling itself, but i think i just needs a little more fine tunning, main problem is its not boosting at all, ive done mulitple boost leak tests and tested wastegate and all was fine, i even installed my 20g and it boosted fine. my mods are: hx35 w/BEP .55 housing, external wastegate off o2 housing, pte 880's, Magnus SMIM, hks 272's,...
hx has no shaft play what so ever, side to side no in n out. spins freely..
heres a an idle log,
I'm no expert, but it seems you are not logging your wb. You (we) need to know what your a/f ratio is.
