ECMlink first log with dsmlink.
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
I went to Vr to get dyoned and tuned, but fuel and airflow is set to zero?is that normal. I did the 2g estimates but knocked 6 degrees?
thanks
What did they do, just turn the boost down untill they say 15deg timing with little or no knock. I sure hope you didn't pay much for that. Did you calibrate your HP/TQ values to represent your Dyno #'s?
This is just my personal recomendation, but you should look into a $90 3.3bar & harness to log accurate boost and a nice $299 plx m-300 wideband. It makes tuning your car emensly easyier! You can do 1-2 things.. Turn your boost up and leave everything alone and see whats going to happen, or just start leaning those fuel sliders out. If you had a wideband I would suggest shooting for 10.5 AFR on pump gas. I would suggest leaving timing alone for now untill you figure out what your going to do. Did you ask for a street tune or somthing?? 14-15psi psi on a 50trim is like running 10psi on a 14b...
