First Log automatic what do you think?
dsm1212
299
Jul 15, 2008
Seattle, Washington
alright this is my first log im new to it and still trying to find out what everything means so tell me what you think
RPM Timing Air Temp Throttle Pos 02 1
718 12 64* 4% .40v 1%
1238 20 66* 9% .92v 0%
1550 23 66 12% .80v -5%
1683 22 68 17% .04v 0%
2085 18 68 27% .16v 7%
2207 5 69 95% .96v 0%
3101 6 69 95 .98v 0%
4027 10 69 95 1.00v 0
4917 12 69 95 1.00v 0
5808 18 70 95 1.02v 0
6523 22 70 95 1.00v 0
5102 12 68 95 .96v 0
4859 12 68 95 .98v 0
5191 14 68 95 .96v 0
5529 15 68 95 .98v 0
5836 18 68 95 .88v 0
6102 20 68 95 .70v 0
6367 22 66 95 .46v 0
6586 22 66 95 .34v 0
4711 34 66 0 .12v 0
this is through second gear into third i couldn't really get just a third gear pull since its an auto, it was boostin at about 10psi since my stock bov leaks at 10 and i have a couple leaks on the back of the intake manifold that are in the process of being fixed. Not really sure what this is telling me. I think that is what the timing is supposed to look like gradually going up with rpms? throttle im not sure why its only 95% since the pedal was all the way down and i don't know what the 02 is, smelled like i was running rich after the pull tho and then my idle was pretty low.
wow that does not look how i typed it i'll try it again
RPM..... Timing..... Air Temp..... Throttle..... Pos 02 1
<br>
718..... ..12..... 64*..... 4%..... .40v 1%
1238..... 20..... 66*..... 9%..... .92v 0%
1550..... 23..... 66...... 12%..... .80v -5%
1683..... 22..... 68...... 17%...... .04v 0%
2085..... 18..... 68...... 27%...... .16v 7%
2207..... 5....... 69...... 95%...... .96v 0%
3101..... 6........69...... 95......... .98v 0%
4027..... 10..... 69...... 95......... 1.00v 0
4917..... 12..... 69...... 95......... 1.00v 0
5808..... 18..... 70...... 95......... 1.02v 0
6523..... 22..... 70......95.......... 1.00v 0
5102..... 12..... 68..... 95.......... .96v 0
4859..... 12..... 68..... 95.......... .98v 0
5191..... 14..... 68..... 95......... .96v 0
5529..... 15..... 68..... 95.......... .98v 0
5836..... 18..... 68..... 95.......... .88v 0
6102..... 20..... 68..... 95.......... .70v 0
6367..... 22..... 66..... 95.......... .46v 0
6586..... 22..... 66..... 95.......... .34v 0
4711...... 34..... 66.... 0........... .12v 0
I would look into adjusting your throttle postion sensor or the cable itself because you are not seeing %100 throttle
i turned it on about 15 min before let it warm up drove about two miles to let it warm up then did the pull and it was about 55 outside
Man. I did a couple pulls and logs and my air temps were 118-120F. Of course it was at the track, where its hott, also it was probably about 80ish out and a good bit of humidity.
I need to lower my intake temps. :rolleyes:
If I'm right, it looks as if timing isn't being pulled but the 5-6 I'm not to sure what it means. I need to learn this stuff too.
:dsm:
ya i don't know what it means either i need to learn but i can't find a lot of info on tuning or logging is 5-6 bad? today when i was idling my timing was going between 5-8 at 750 rpms and i saw that somehwere on the drive home (just normal casual commuting it had gone to -4 was the lowest the timing went please help.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
