What do you think of this log?
98gst14b
453
Jan 24, 2006
Keys, Florida
Mods are in profile, I wouldn't rely on the o2 voltage at first I couldnt get anything at all maybe .02-.04 at times but #2 sensor gave me some readings, I cant understad whats going on here and why timing gets pulled so late and when the afr is actually where it should be (.92)?? Opinions? Thanks
RPM Tmg TPS O2 #2
855.0 12.0 0.0 0.02
1414.0 7.0 9.82 0.92
2148.0 24.0 33.79 0.9
2383.0 25.0 95.09 0.14
2758.0 26.0 95.09 0.08
3391.0 25.0 95.09 0.66
4180.0 23.0 95.09 0.1
5559.0 11.0 95.09 0.98
5957.0 14.0 79.37 0.82
6645.0 18.0 77.8 0.24
it wont log like that the more data I select the less time it logs and im running 18-20 psi (in profile)
No its an automatic so either I do it in 1st or figure out a way to put it in limp mode, and I did WOT it i guess the tps doesnt see it as 100%...
is it possible that it is too rich? The timing seems to get worse from -34% to like -27%. I cant get a rading from the front o2 only .02 - .04 volts.
