First gear fuel cut
stretchskeletor
Sep 17, 2009
augusta, Kansas
My car has a 6 bolt motor with a 60 trim turbo and is setup with a gm 3 bar map sensor so the bov vents externally but in first gear and first gear only the car either hits a lomiter or fuel cuts at 5000 rpm but when I shift to 2nd or higher it pulls hard all the way to 7000 what could be the problem the car does have a dsm link but I don't have a laptop to look at the settings. Thanks for any help.
i hope you have some sort of fuel mods and not just the big 60 trim on stock fuel system
Yes it has a 255 LPG pump and 780cc injectors and an aermotive fpr set at 33 psi boost is set at 23 psi the car has a rial external wastegate and a rial 50mm bov and a manual boost controller. The turbo makes 10 psi at 3000 to 3500 then spools to 23 by 4500
I talked to a guy here he said 23 psi on pump gas was to much so I turned the boost down to 18 and fuel pressure to 43 psi and it fixed the first gear fuel cut and now it happens in 3rd and 4th.
I'ma newbee but I have heard not doing the wire mod to the fuel pump can cause problems in higher boost and rpm's also the FPR should be on stock fuel settings. Just taking a stab at it but also whats the fuel filter look like? whats your speed and rpm in those gears when it cuts? I may be wrong with this but its areas I would check
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
