knochgoon24
DSM Wiseman
- 6,135
- 98
- Jan 29, 2008
Troy,
Michigan
No hidden cost besides the sensors. Unless you need to get a bung welded into your IC piping. But even then, you could probably thread it into the stock TB or IM somewhere.
I haven't had to much of a problem with it. Easiest way to tune it would be to leave the MAF in and use the built in SD calculations to tune it. Then once you get it all close, switch it over to the SD.
I've had to add some extra enrichment for when it's cold, but otherwise, no big problems.
