General DSMchips 98/99 ECU + MAFT
Madcap
57
Jun 7, 2006
East Douglas, Massachusetts
Thinking about get a flashed ECU from DSMchips. I'm currenty running a MAFT and was wondering if they work well together? Also think about ditching the tuning ability of the MAFT and going with a NEO.
if you are running with a GM MAF then you will need to keep the translator, the NEO wont do the conversion. also for the price of the NEO you can pick up an openport 2.0 cable and tune the 98/99 ecu your self. there is a bit of a higher learning curve than ECMlink but you will spend a lot less in the long run and you wont need any extra hardware to do it, not to mention with either the 98/99 ecu or link (if you wanted to) you could eventually ditch the translator and speed density.
