m_0ney_pit
- 819
- 87
- Jan 12, 2007
Easton,
Pennsylvania
Take the plastic cover off and look at the board revision and number. If it matches the 98/99 revisions and numbers it will probably work. Part number won't tell you much.
Since your non-US its probably more like the evo5/6 ecu which you can still flash but you'll have to use the appropriate rom and definition from an evo or write a def for your ecu.
It's cool having the ability to mod your code. I use 1G Eprom ecu with my 6-bolt and the Ostrich instead of a chip. So I can upload whatever I want on that thing and do whatever I want to with it. Now I can use TunerPro ($30) to tune it and later this year I will move on to speed density and upload the Jackal (freeware).
And all this for $170 (Ostrich price). No extra sensors (except MAP and IAT), no payments for software upgrades and stuff like that...
So I am looking forward to find a way to reflash my friend's ECU when the supercharger is bolted and tune his ride.
I just got the numbers of my old ECU but it is not as the ones above. How can I find if it is H8 compatible?
md36410
e2t68277
je331b153c
u can try take signal from abs sensors or maybe instal one on rear wheel and 2nd on front wheel
just for traction control.
