First dyno results
Nofear20
345
Aug 9, 2007
Yakima, Washington
285whp with over 300lbs of tq spiking at 24 psi dropping off to 22. Mods are in my profile. Does this seem a bit low or am I just expecting too much? I thought I'd reach 300. Looking around at other peoples dynosheets with the same mods as me or even less mods and they all seem to dyno better.. :hmm:
At 22psi you should have made at least 350hp-375hp.
you can't really say that... it could have been on a mustang dyno with 9:1 a/f and like 7* timing with out more info a statement like that is plain stupid...
possible things affecting would be the tune(most affect), fuel octane( not much tho), timing..and the clutch may be unnoticeable but slipping? but yeah, post a log and also what is your afr? guess we should be able to see that in the log tho...LOL and whatever dyno it is would affect it also...
I am aware of that but i was saying with a normal decent tune he would get that hp and he didnt mention any a/f ratios or timing so i was assuming the normal thing, i have the same set up and with my dsm link on 20psi i made 350 hp, so take it easy its okay masterWTF
It was on a Dynojet. I'll post up some logs when I get the car back tomorrow. My tune may be somewhat conservative because my tuner knows this car is my daily driver and my only car so I can't be messing something up....and tot he guy that said 350 to 375.. yeah i wish LOL
and tot he guy that said 350 to 375.. yeah i wish LOL[/QUOTE]
You should, cause i got the same set up, but just keep your eye on the a/f ratio, timing and check the fuel trims make sure you are getting enough fuel
English Racing did the tune... so I know it was done right... just wondering why I'm not comparing to others.
That's a drive ...
Ya I figured that you dyno'd down there...
I'm pretty sure that lucas could get you alot more out of it,If you wanted
Was this just base line pulls the other weekend or did he do some tuning?
I think you may have answered yourself already
If your still worried about messing up your DD
I would have to say get a new DD... Get some bigger injectors run E85 O and a better clutch too... How far is sunnyside from where your at? their's a station there and go for broke have Lucas get as much as he can out of it...
I *think* I have a somewhat conservative tune. I'll post it up as well as a log tomorrow.
Here's the timing and fuel for the 24psi tune.
12-14 of timing in peak torque and raising it up to 20 until red line is fine
for AFR high 10 in peak torque lean it between low and mid 11, little more rich at red line
that would be a safe dd tune on pump gas
so ... why are tuners hiding horse power ???
BTW with your set up you should be in the 350-375
Hey guys, here's my dyno sheet. Still haven't had a chance to get a 3rd gear log yet
