soldave
- 737
- 2
- Feb 17, 2008
Okinawa, Japan,
Asia
OK - I'm 18 days away from taking part in my first drag race tournament: the HKS Drags - Okinawa. Touch wood the car will be ready; I've got a Punishment Racing manifold on order, and will be fitting a ported O2 housing, and maybe a new frontpipe to replace the stock one. Will be getting a meth kit too if Devils Own can sort out the current issue I'm having when placing order with them. So the car should be ready, but I need to be!
Let me give you a bit of info on the event first. Okinawa's main "circuit" is a bit of a joke, and is basically an area of land the size of a car park. Consequently, the drag run is only 150m or 1/10th mile. It should also be noted that the surface is damn slippery (the asphalt up there is coral-based meaning getting traction is key). The event itself with be in time bracket racing.
Now I've done some reading about the staging lights and how to properly launch (will have to be 4500-5000rpm so as not to just be spinning my wheels at the start), but wondered if anyone could offer me any more advice. I have read the advice threads about launching and shifting, and will probably shift around the 7300rpm mark, as I'm still making power until then. I'll be taking the wing off the car and also letting a little air out of the tyres to keep traction. Am excited about this, but already a little nervous as I want to put in a decent performance there. Thanks for any advice you guys can offer me
