Firewall connectors?
Crasher
Nov 12, 2009
Everett, Massachusetts
I was doing a little engine bay clean up the other day and cut these 3 wire mounted on the firewall.They had connectors on them but didn't have a wire on the other side of the connector and didn't look like they went to anything so I cut all 3 of them.Little did I know that when I started my car it barely held an idle.I had to re connect everything and it sucked.One connecter has 2 wires coming from it the other 2 have 1 wire going to it.They are held by a little bracket on the firewall.Can someone tell me what they are and what they do?
The picture is old by the way
Well heres a close up of what I had to do last night when I was stuck at work in the dark with no flash light :banghead: Here are the connectors.Can I just take the blue connector off and solder the two wires together?
Thanks by the way
So I will remove those connectors and solder then together.I'll get ride of the brown connecter and the small black connector and I should be fine.Your one fart smeller I mean smart feller.Thanks Brian
On another note I can remove the small black and brown connectors completely right?I'm trying to get rid of as much as possible I wasn't too sure what you meant by fuel pump test?That mean that mitsu takes a connector and connects into it to test the fuel pump.Sorry I'm completely stupid on the electrical aspect of things
