2G Filling Extra Trans Fluid?
Kai Hefner
Freelancer
481
283
Jun 21, 2018
Calgary, AB, Canada
Hey all.
Was reading on what exact lubricant to use for my trans and I got everything figured out to do a fluid change around the entire car. I remember seeing a comment on one of the threads about a method to remove the reverse switch (or something) to fill up the trans a bit more. Apparently it was recommended by Shep or something along those lines. Anyone have exact details on this?
I usually always fill my trans from the reverse sensor hole, I pop it out, remove the filler plug on the transmission and fill until I see it running out on the filler plug.
I think he is referring to running more fluid than factory spec, but correct me if I'm wrong OP.
FWIW: i also run factory spec with fluid levels.
That is mostly what I was referring too but I guess factory spec is probably good enough for me.
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
