MOPAR S9417= what manual trans fluid
Xtreme Legion
94
Apr 18, 2011
Springfield, Massachusetts
I picked up royal purple but when I got home my haynes said use MOPAR S9417 or equal manual trans fluid
Sent from my HTC Glacier using Tapatalk
Tranny needed ATF + 4. If someone knows I can def use royal.purple ill swap on next flush
Why you use the ATF+4 is that Chrysler designed the tranny with felt lined syncros. ATF+4 has what's called an FM - "Friction Modifier"- that works with the lined syncros.
Other fluids don't have the modifer, thus the syncros can eventually self destruct.
..and the same with Chrysler and DSM Mitsu auto trannies: ATF+4 is also used. Don't use Dextron, or that stuff will destroy the friction discs in the tranny..
So using the ATF + 4 is better then running the ROYAL PURPLE 75W-90
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
