Fidanza with oem pressure plate and clutch
pitbull419
981
Dec 31, 2004
port clinton, Ohio
Has any body ever used a fidanza flywheel wit an oem clutch an pressure plate?
If so did you have any trouble getting the pressure plate on.
Did you have to file anything of the pressure plate.
I went to put my pressure plate on and it wouldnt work.
When the key ways were lined up only 3 bolt holes were lined up.
When all the bolt holes are lined up the key ways arent.The key ways are almost in the holes but not enought to even force it on(which i wouldnt).
Should i file the key way holes on the pressure plate out so they will fit?
Thanks
Car is a 6bolt awd
Its not the flywheel is it?
I mean say the accidently sent me a fwd or a n/t the key ways and bolt holes are still the samr correct?
I know they didnt but i thats the only thing i can think of why it wont line up.\
Could my preesure plate be warped?Its never been driven on but I did my clutch job first and was having dissengagement problems so i decided to go ahead and get a fidanza flywheel.
I need help asap i need my car back
NA, FWD and AWD use different flywheels.
Why not compare this flywheel to the one you took off the car?
It is possible to warp a pp during installation or removal, but that will not cause holes to not line up.
A new flywheel will not solve the disengaging probelm.
    • george bromwell
    • pma1123
    • Sdcryan1
