Fidanza short shifter 1G & 2G [Merged 3-7]
To those who have bought the 1G Fidanza Short Throw, maybe you noticed this also. Theres no stop!!! I beleive that using this shifter will make it possible to overthrow the shift forks in the trans causing them to break. Im trying to see if anyone else has drilled a bolt through the darn thing and threaded in a bolt to act as a stop. I dont think it would be to hard doing that part, but I'd like to rap the protruding bolt with something so I dont get a clank everytime I shift. Damnit, $80 for a shifter. You'd expect the dam thing to be made right. :mad:
Comments?
I already broke a 3/4 shift fork last week. I pulled my trans, replaced the fork, pulled the shifter and threw it in the garbage. Waste of money. :mad: After a few hard shifts you WILL break a shift fork. You can probably drill a hole(s) in the shifter base and put an adjustable bolt on both sides to control how far the shifter will move but I'd rather just use my stocker.
:thumbdown
Also, I'm not sure how similar they are but I have a pacsetter short throw shifter that was missing the stopper too. I just pulled the stopper off my n/t and put it on the tsi. :)
Thanks for the link, Im gonna try and rig something up. This really sucks, i wanna use the shifter for the shorter throw but I sure in the hell dont wanna break anything. Thanks god I havent drivin on it yet. This really chaps my ass. :thumbdown
This is the OBX shifter, Identical to the Fidanza. I circled where a stop is suppose to be.
Ryanman - Do you shift hard? Cuz dam thats really shitty.
Well, Im usually not to hard on the thing, I shift slow or pretty easy on the thing because I know these tranny's dont like it. Im still gonna make a custom stop in the lever for added assurance, but I recommend to all using the 1g short shifters without a stop, go easy on it, dont pile drive the thing into gear without a stopper. You can end up like ryanman.
I'll post results in the next few days of my custom work with the thing. :|
I've been trying to find a good short throw shifter for a 1G as I dont have access to a welder to cut mine down.
Well today well I was looking for some other parts I happened across Fidanza Short Throw Shifter for 90~94 DSM's. I've never heard anyone speak about these before. New? Anyone know how good they are?
They only cost like $10 bucks more then it would cost me to have a local shop mod my stock shifter into a short throw.
i wanted to know if anyone was using the Fidanza shifter and i wanted to know what everyone thought of it. It is a lot cheaper then the B&M, but from what I hear Fidanza makes really good products.
ryanman said:
Yeah and I broke a shift fork inside the tranny 5 minutes after I installed it. :thumbdown
:rolleyes: Yet your blaming the shifter on it, when everyone knows the shift fork is a weak point of the transmission
And? They should've put a stop on the shifter when they built it.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
