Type1DSMr
- 1,116
- 163
- Jul 27, 2014
Jasper,
Indiana
1). Any boost, vac, or exhaust leaks? Boost leak tested 5psi above your max boost with no leaks?
None only tested to 18 psi. I run low boost til upgrade
2). Verified mechanical timing?
yes
3). Verified base timing?
yes
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: Ngk couple of months old less than 2000 miles
Spark Plug brand, type and Gap:
Ngk 6es .28
5). Motor health (Compression Test)
Cylinder 1:175
Cylinder 2:170
Cylinder 3:170
Cylinder 4:175
6). Performed basic throttle body adjustments?
Idle Switch: Yes simulated
Throttle Cable: Yes
TPS: Yes .63 volts
BISS: Yes, but can't adjust since injector upgrade. ISC was at 30 but now all over the place
7). Compression ratio Stock 7 bolt
8). Any known bad sensors or brittle wiring? No
9). Any DTC/CEL codes? No
10). Electrical system
Car off (not running):
Car running: 13
11). Base fuel pressure and injector values
Base Fuel Pressure: 43.5 without vacuum line/ with line only 38
Injector Size (cc/min): 1120
12). Properly calibrated and configured wideband sensor
Sensor Brand: Innovate MTX-L
Calibration Date: 3 weeks ago
13). Type of fuel
Type: Gas 93 oct
Percent of Ethanol:
14). Watched ECMlink how-to videos? Yes
I just install some FIC 1120cc injectors along with a Fuelab 515 reg and set the based pressure to 43.5 with the line off, but when the line is connected it drops to 36-38psi. Everything before swap with tune in good at ISC 30, idle afr 14.7, and ran good. I've input the injectors values per FIC data sheet and set the global, even tried multiple settings but no avail. Still on an evo 9 pump, but I have a walbro 450 pump ready to install. Here's a log take a look please. Thanks
yes
yes
4). Ignition system
Ngk 6es .28
Cylinder 1:175
Cylinder 2:170
Cylinder 3:170
Cylinder 4:175
Throttle Cable: Yes
TPS: Yes .63 volts
Car running: 13
13). Type of fuel
Type: Gas 93 oct
Percent of Ethanol:
