fiav block off questions [Merged 11-8]
96whgsx
745
6
Sep 28, 2004
San Francisco, California
I did a boost leak test recently and I found a very good sized leak probably on the TB shaft seals. So, I'm just going to replace them and while the TB is off, I was deciding whether I should block off the FIAV and blocking off both the FIAV and ISC. I know that some people have had trouble with cold starts on cold days but the weather here doesn't go below 50 F so, I'm not too worried about that. Also, the vfaq for removal/bypass of the FIAV isn't working, so I have yet to read an write-up/article on this subject. I do know that you can JB weld one of the ports or buy a blockoff plates and re-route the coolant lines to bypass the throttle body. Thanks in advance for the replies.
