Feedback On GSX Setup
Shane2GSX
423
24
Oct 13, 2005
Louisville, Kentucky
First off, I have done plenty of research on the different aspects of my setup as well as different profiles of people with similar times as my goals. I'm hoping the mods below will get me to my goals, and from the research I've done I think they will. However, this is just a rough draft (for lack of better term) of my planned setup. All constructive criticism is welcome. If anyone has any comments or suggestions please post. Thanks.
Platform:
1999 GSX - 56,000 Miles (Completely Stock) MT
Not my Daily Driver
Goals:
Low to mid 12 second 1/4 time *EDIT* On Pump Gas *EDIT*
Hoping for something in the range or 300-350 AWD HP
Stock weight
Initial Mod List:
Boost, EGT Guages
Apexi N1 3" Catback
Apexi 2.75" DP
Colder Plugs
Dejon Tool Intake
Blitz SS BOV (old style)
Greddy Profec B BC
ACT 2100 or 2600 *EDIT*
Apexi SAFC II
GM MAF
MAFT
Walbro 190 or 255 *EDIT*
650's
Evo III 16G (ported) or 20G not sure which yet
FMIC w/short route 2.25" piping
Future:
DSM Link
Light weight racing rims
Cams
Updated Mod List: (Edited*)
NGK 7's
K & N Intake Filter - Installed
Blitz Dual Turbo Timer - Installed
A-Pillar Pod (Gaugepods.com) - Installed
Boost, EGT, and Oil Pressure Gauges (Autometer) - Installed
Megan Racing 3" DP and Catback - Installed
Blitz SS BOV (Old Style) - Installed
Hallman MBC - Installed
3" Dejon Tool Intake
Megan Racing Short Throw Shifter* - Installed
Symborski Shift Kit* - Installed
SBR 3500 Clutch*
XACT Streetlight Flywheel*
PLX M-300 Wideband Kit
Walbro 255*
AFPR
PTE 780cc Injectors (not sure which)
95' EPROM ECU - Have
DSM Link
50 Trim (PTE T-Tech Ball Bearing 5031)
38mm Tial WG off O2*
VP O2 Housing (Recirculated)*
Ported 2G Manifold*
XS Power FMIC Kit - Have
ARP Headstuds & Headgasket*
Future:
264 HKS Cams
Lighter Weight Rims
Springs*
actually thats not a bad idea. if anyone in CT wants to buy my megan exhaust for what i payed with the shipping ill install it for them. its a turboback. the only thing we will need is a test pipe from megan or a hi flow cat. i can call them up and get it.
to the best of my knowledge when i talked to megan tuesday they were selling the 2g awd turbo backs. as for the rnr i dont even remember what they look like. you need to run the o2s for the car to run right if that helps. i payed a little on the high side for my cat back 450$ shipped which is cheap but high for what i think they are going to sell them for. plus the downpipe was 170$ shipped. but i bought it from www.thespeedfactor.com. im a little upset cuz they told me it was 450$ for the turboback then i got the catback and was like wheres the downpipe. they then told me that ooo there was a bidding war on who got the prototype and what not so that was the price on the catback or something. it sounded kind of shady when i called Megan. Megan told me they had the 2g awds done and where already in production and speedfactor told me that they had the prototype and Megan was waiting on me for feedback. but at any rate i got it. its all computer TIG welded; perfect welds. all polished piping, even the flanges are polished. not to mention you get all the gaskets and bolts you need. there is also two adapter pieces one to bolt up a stock downpipe and one for the 3in downpipe. im very impressed!!:thumb:
A more common solution for wideband sensors is to mount the wideband O2 in the rear O2 bung.
Okay, so the wideband O2 needs to take measurements from the rear 02 instead of the front? It only needs to measure one and not both? If I get a turbo back with an O2 eliminator I can just plug in the wideband O2 where the bung is? I appologize for the newbiness, again. :coy:
Shane buddy let me break this down for you in easy to understand terms
-02 eliminator means the o2 housing is part of the downpipe(you probably dont want that if you in the future want to switch to a full garrett turbo setup)you will then need to purchase a new downpipe and 02 housing
-with the stock computer inline you always want both o2 sensors plugged in. They are critical to making the car run good. THE REAR O2 AS WELL!!!! It does check to see if your cat is working but it also uses the values to help the computer make its air fuel adjustments against popular belief
-you have two choices with the widebands
1)a narrow band /wideband sensor can be used in place of the stock leading sensor. this will allow the computer to read the narrowband for engine paramaters and you will be able to view wide band o2s on your gauge/device
2)simplier and cheaper option when u get your turboback exhaust have a bung(where the o2 sensor is probed into the exhaust) welded on to it close to the beginning of the downpipe (better readings the closer to the engine you get ). This will allow you to keep your stock o2 sensors in place and take measurements from your wideband in a separate location
Good luck
glenneclipsegsx:
Since I dont' know what turbo I'm getting, I will not get an O2 eliminator.
I believe I'll get the PLX-250 or 300 (not sure what the differences are but the 250 is cheaper) to read both narrow and wb. I can just use it to replace the front O2 and it will read both. This is a bit more expensive than option 2, but I like the simplicity. Plus it has a digital readout which will save me from buying a gauge.
Thanks for the help. :D
The only difference I can see is that the M-300 has the bosch digital display and the M-250 does not. Other than that they appear to be the exact same and have the same features.
I will probably opt for the M-300 so I can see what's going on.
