2G Fan Wiring
redeclipse7782
463
7
Oct 20, 2004
Worcester, Massachusetts
Radiator
White-Black + (Lo)
Black - (Lo)
White-Blue + (Hi)
Blue-Green - (Hi)
Condensor
Blue + (Lo)
Blue-Black - (Lo)
Blue-White + (Hi)
Black - (Hi)
Source: 1998 Mitsubishi Factory Service Manual Vol3
When installing an aftermarket fan such as a slimline wire the positives together and the negatives together.
Example:
White-Black \
Blue (+) (slimline)
White- Blue /
Black \
Black (-) (slimline)
Blue-Green /
Radiator
White-Black + (Lo)
Black - (Lo)
White-Blue + (Hi)
Blue-Green - (Hi)
Condensor
Blue + (Lo)
Blue-Black - (Lo)
Blue-White + (Hi)
Black - (Hi)
Example:
White-Black \
Blue (+) (slimline)
White- Blue /
Black \
Blue-Green /
So i just thought i would reply here because their is a mess up on the writing here and i made the mistake it said. It shows you connecting a LO and a HI together when it should be HI+HI. Like white/blue and blue/green are both HI.
I know its old but if i can still make this mistake from reading then others can to! Make sure you check the wires to be HI and ignore the example as it will guide you wrongly
You're saying to connect hi+hi together and the wires are white/blue and blue/green. Your photos show you connected white/blue and white/black. Then black with blue/green. Wouldn't that be hi+low/hi+low?
I would have imagine it would have been white/blue with blue/green. Then white/black with black.
It looks like its been edited to now be and show correctly as before it did not do this, normally i have screen shots to fall back on to but for some reason i never took one on this page just another page for wiring
