Miasma
- 443
- 58
- Aug 22, 2012
Fort McMurray,
AB, Canada
Hello,
I am in the process of installing some Performance World 7712B slim puller fans for my Mishimoto dual core aluminum radiator, using a Mishimoto radiator shroud on my 1998 Eagle Talon TSI.
I've treading reading through a few forums, but can't find a clear answer that will help me figure out my issue.
I've wire both fans together to trigger them both on at the same time, and I'm trying to use a 50A relay harness to power them to avoid blowing factory fuses.
Attached is a picture of how I'm wiring them and a wiring diagram I found when trying to sort this out.
I would like my fans to turn on like the factory driver side fan used to, based on engine temperature. So, I'm really curious what I'm doing wrong.
Can those of you who have wired your fans with a relay please chime in.
Thank you,
Aaron
- Pin 30 is connected to 12V battery power within the fuse box in my engine bay.
- Pin 86 is connected to 12V switched power, also within the fuse box.
- Pin 87 is connected to the positive leads for the fans, and the fan negatives are chassis grounded
- Connected Pin 85 to the Solid Blue wire from my driver side factory radiator fan harness. This resulted in no power to the fans with the engine running at operating temperature.
- Connected Pin 85 to the Blue/White wire from the driver side factory radiator fan harness. This also resulted in no power to the fans with the engine running at operating temperature.
- Connected Pin 85 to the Black/Wire wire from the driver side factory radiator fan harness. This results in the fans running with the Ignition ON, regardless or the engine running or not, indicating to me that the relay is being grounded when switched power is turned on.
Thank you,
Aaron
