Fan adjustment in link
I'm running V3, so I'm not sure if this works with V2 or not, but you say the fan is running constantly with the key on? Well, under the ECU Config section, in the misc. tab, is a box you can check to have fans run full on. Did you look to make sure this box wasn't checked?
