Low Timing value in link
RocCitySlayer
792
7
Nov 20, 2011
Rochester, New York
What would cause the timing value to log 0.1 at idle? Wideband read perfectly at 14.6-15.1 but the cars idle was rough. I completely forgot to save the log to my laptop or I'd post it. Lrndidle was soild 144, Battery was 13.8, Isc was 35 or so airflowperrev was .25-.26. Im not sure what base timing is because I don't have a timing light just yet.
This makes your question useless knowing you have a 1g CAS. If you didn't set timing with a light, it could be anywhere. Figure that out first, then reevaluate your situation.
Ok I'm going to try to get ahold of a light. Also I changed out my ISC, it works now. The old old ones plunger had so much play I could literally move it all around.
