extreme psi nos kit
I would do the upgrade paths. Nitrous requires more than just that kit. You'll need tuning and fuel. Try the basics before going right in.
Assuming that it is a dry kit than you would be correct, but a wet kit has fuel solenoids as well as nitrous solenoids for fuel enrichment, so you can in fact add just a wet kit without tuning. It would be a good idea to retard the timing a little, but is not 100 percent necessary with a small shot.
What I was getting at, is I would t reccommend putting that kit on with no other modification at all. Your putting a lot more stress on the motor that's needs to be.
What modifications do you suggest. If properly jetted it will put no more stress on the engine than a turbo will. Is is just adding more oxygen into the cylinders. A 75 or 100 shot would be perfectly fine if you have the proper fuel pump, and the setup tuned right.
But with what we can see about this user, there's a pretty high chance he has no idea what he's doing.
